Author Topic: Fastest motherboard with at least 1 ISA slot?  (Read 5054 times)
Offline bob225
Re: Fastest motherboard with at least 1 ISA slot?
« Reply #50 on: September 24, 2018, 01:26:30 am »
ah the joys of old hardware, those where the days when you had to properly diagnose problems not just click a box and software fixes it for you
Any IRQ, I/O or DMA conflicts between the cards ?
Offline precaud
    • LinearZ
« Reply #51 on: September 24, 2018, 01:45:20 am »
No problem there, the ISA card only uses a couple IO ports and doesn't use IRQ or DMA, its all programmed IO controlled by the software.
I sense you're heading toward suggesting a USB->ISA adapter. I have confirmed with the mfr that it won't work, those converters require some software changes.
Offline bob225
« Reply #52 on: September 24, 2018, 03:15:23 am »
not at all, the usb - Isa just adds another layer of complexity and another driver in the mix, as you need Isa you have to stick with a chipset that natively supports it (agp graphics era)
iirc some of the older usb chipsets dont play nicely with others (winbond springs to mind)
« Last Edit: September 24, 2018, 03:20:31 am by bob225 »
Online drussell
  • Hardcore Geek
« Reply #53 on: September 24, 2018, 03:20:29 am »
...shows a Biostar M7MIA that has one ISA slot, uses the AMD 761, and DDR memory. Limited to 1GB of memory, though (the Soyo does 1.5GB).
The specs I saw said 2GB maximum, but maybe they were wrong.
EDIT: Well its not all that rosey... it appears Biostar never updated the BIOS to support the faster XP+ cpus, so the fastest cpu it supports is 1.4GHz. The Soyo will run a XP 2600+ (1.91GHz). Grrrrr...   |O
You might be able to cobble together a custom BIOS but that is a lot of effort.  :)
There are also Intel 845 based boards (ick, P4) that do up to 333 MHz DDR supposedly with a "real" ISA slot with working DMA, etc.
Although... since you say:
... that you don't need DMA, then any newer board that has a PCI->ISA bridge or LPC->ISA bridge on it should work, though it has been so long I don't remember how the IO ports would get mapped in there.  It is usually DMA that causes the problems when trying to do ISA since newer chipsets simply do not support mapping that stuff to where it needs to go.
Not USB...  That is icky.  PCI, though, you should be able to use your own PCI->ISA bridge and have success (or any motherboard that has one built in like some of the SuperMicro boards, industrial boards, etc.)
I guess I need to go back and do some more reading and re-learning.  :)
« Last Edit: September 24, 2018, 03:22:14 am by drussell »
Offline bob225
« Reply #54 on: September 24, 2018, 03:31:44 am »
oops i missed 2 posts on page 2 - i see you had to get the drivers in the right order - i forgot that was a thing back then
It surprising what you forget, new info in - old redundent info out  :-\
Offline precaud
    • LinearZ
« Reply #55 on: September 24, 2018, 04:33:40 am »
Yeah, I disabled the onboard USB before installing a USB2 card.
Which reminds me of something I wondered about briefly when putting this together. (Pls correct me if any of this is wrong).
Max xfer rate of USB 2.0 is spec'ed at 480Mbit/sec, or roughly 48MByte/sec.
To achieve that rate, it has to be attached to a mboard bus that supports that xfer rate.
But PCI busses are clocked at ~ 33MHz.
This suggests that no PCI plugin USB 2.0 card will ever achieve 48MB and will be limited to < 33MHz xfer rate. It may be protocol-compliant, but is transfer-rate limited.
If so, then this is also playing a big role in slowing things down. And no machinations of cpu or memory speed will make up for it. It probably explains why the Soyo was not more than 2X faster than the Tyan combo. By all rights it should have been.
Definitely not worth it !
There is indeed a SuperMicro P4 board (the P4SCA) with two 16-bit ISA slots that looks like it would work well. But they're industrial darlings and pull a minimum of $400 used...
Yeah, wasn't that fun?!?!
Maintaining sanity (or some semblance thereof) requires that we forget such things  :)
Online drussell
  • Hardcore Geek
« Reply #56 on: September 24, 2018, 04:42:31 am »
You forgot that it is 32 bit, not 8-bit, so the standard 33 MHz PCI bus gives you 133 MB/s transfer rates.  (So an ATA-133 card with a modern disk on it uses the whole dang bus...  :) )
The following users thanked this post: precaud
Offline Wan Huang Luo
  • 顽谎骆 from the Shenzhen Market
« Reply #57 on: December 06, 2018, 05:33:07 am »
Never mind. I just ordered the caps to recap them both and I'll go that route.
I did that with Soyo boards back in the 90's. The originals lasted a couple of years. After replacing the caps with quality Japanese units the boards were taken out of service (retired) last year after ~17 years of 24/7 use. At the time it seemed nuts, but they were the only boards I could find that had the right chipset and form-factor to fit the requirements.
If you already have boards that work, then stick with those. The more pre-heat you can get into the board, the easier it'll be to re-work the caps. Motherboards have huge internal planes and really suck the heat from the joint.
For DIYers, Soyo boards used to be the duck's guts way back then.
Offline precaud
    • LinearZ
« Reply #58 on: December 06, 2018, 11:47:57 am »
[/quote]
Yes, but very stable too, not as tweaky as, say, the Abit's which gave you insane overclocking options...
« Reply #59 on: December 07, 2018, 01:33:24 am »
Ah yes, to be back in the heady days of 200...1? with an Abit KT7A-RAID, and an AMD Duron  with pencil graphite over the multiplier traces, enabling unlock and bringing 600MHz to 1GHz, stable with some $25 heatsink. And twin IBM Deathstar drives in RAID-0  :scared: :-BROKE
