As a follow-up to the A770 story I thought I would share my recent good fortune regarding a part used in it. A case of better born lucky than rich me thinks
I was looking for an extra A770 hard disk caddy so that I could change operating systems to suit the computers tasking. Those familiar with Military spec laptops will know that the caddy's used in these computers are generally more complex than those of standard laptops. They often use non standard connectors and contain heater plates to keep the mechanical hard disk bearings warm in very low temperatures. This tends to mean that the caddy's for rugged laptops are both scarce and expensive. Many such caddy's retail at £50 to £150 each ! Not great when I just bought the whole 'as-new' laptop for less than £60.
I also needed some caddy's for my Ex Military Getac M230 laptops. They came without the hard disk (and sadly associated caddy) for obvious reasons. A HIROSE (HRS) high density D shaped connector is used on the caddy and I have discovered that this connector is now discontinued and unobtainium
I was faced with 'hot wiring' a standard hard disk connector into the motherboard to circumvent the HRS connector or to pay around £80 for a used M230 Caddy on ebay. I need 8 of them !!!!
I could also fit a hard disk CD bay caddy at only £8 each but then I lose the DVD writer capability which would be a pity.
Back to the A770 caddy.......
My searches for the Caddy were at first fruitless and no one was offering any A760 or A770 caddy's either on eBay of via direct sale, at any price
I did some lateral thinking and decided to use some different search search terms including the caddy's MITAC part number (GETAC was part of MITAC). Luck was on my side this time around. I got a hit on some caddy stock on a surplus sellers web site. Better still they were in the UK
The price ? .... well this is where things got interesting.
The UK company listed the required complete empty caddy unit under its Mitac Description and again under just the part number. The first was priced at £7.50 each and the second at £3 each. I thought it likely that an error had been made in the stock listing or the second unit was not a complete assembly, likely just the outer shell with no 'guts'. I contacted the seller with some trepidation. I hoped to buy 10 caddy's at £3 each but if the seller identified an error they might cost me £7.50 each. The seller responded saying that the caddy's were burried in the warehouse and would take time to find. After a week of no word from the seller, I decided to buy 10 of the £3 caddy's and one of the £7.50 caddy's to see the difference and I thought it worth the risk. I would at least have one complete caddy for the A770. Postage was £7.50 and I submitted the order.
The same day I received a note from the seller explaining that they needed to check for stock availability. Oooops that did not sound promising
He contacted me again the next day to explain that indeed an error had been made in all web entries for the caddy.... description, stock holding and price
He said he had 11 caddy's and was going to honor the £3 price on 10 and £7.50 on the one. Good man
He even gave me next day delivery at no extra cost.
The 11 caddy's arrived today and are complete, brand new in their packing
Why did I buy 11 ? Well dear readers, the caddy is different to that used in the M230 laptop, but the connector used on it is the same on both models of laptop. That unobtainium connector is now mine for £3 each plus I have the basics of a caddy casing to convert to the needs of the M230 Hard Drive dock. I needed one extra caddy for the A770, eight for the M230's and two spares
I count myself as very lucky at the moment. Not only did I find the caddy for the A770, which is in itself rare, I also discovered that it uses the same connector as the M230, the seller had multiple units to sell and the seller honored an incorrect price for me. Happy days
As I said, sometimes it is better to be born lucky than rich (I would not mind trying rich some time though
Fraser
