Author Topic: I miss 'FORTH' the programming language  (Read 8661 times)
Offline GlennSpriggTopic starter
  • Medically retired Tech. Old School / re-learning !
« on: September 03, 2018, 02:26:22 pm »
Countless fads in life come & go. This should have stayed, as it is/was so different !!
It relies heavily on 'Stacks', and 'R.P.N.' for calculations, but was so easy to implement.
'Command' words were based on certain 'Primitives', from which you built higher and
higher level 'Words' from. To the end that you virtually create such a 'High' level 'Word'
or instruction, with certain parameters, that their is no 'program' as such.
It was used inside a lot of Chips in specialized instruments for quite a while.
I won't explain more here, but will if asked !!  :)  It REALLY shouldn't have died....
« Last Edit: September 03, 2018, 02:28:03 pm by GlennSprigg »
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
The following users thanked this post: elecdonia
Offline NivagSwerdna
Re: I miss 'FORTH' the programming language
« Reply #1 on: September 03, 2018, 02:39:41 pm »
I have GForth on my Android phone.  Looks alive to me.   :)
Offline ebclr
« Reply #2 on: September 03, 2018, 02:41:56 pm »
Offline artag
« Reply #3 on: September 03, 2018, 06:47:22 pm »
Postscript is based on it. I don't think that's died.
Offline kizmit99
« Reply #4 on: September 03, 2018, 08:08:42 pm »
ebclr - thanks for posting the link to the video  :-+
I used Forth for a summer back in the early eighties as a co-op student with IBM.  It's certainly "different" as languages go, but it's also enchantingly elegant...
Offline borjam
  • EA2EKH
« Reply #5 on: September 03, 2018, 08:46:52 pm »
I used it for embedded systems in the early 90's :) I was a member of the Forth Interest Group even.
By the way, Mitch Bradley (the original Open Firmware author) has a Github repository with his CForth implementation.
https://github.com/MitchBradley/cforth
Offline daybyter
« Reply #6 on: September 04, 2018, 01:47:18 am »
Just did some work on a zylin cpu implementation. Pretty similar and also very alive.
Online darrellg
Offline RoGeorge
« Reply #8 on: September 04, 2018, 06:06:12 pm »
Forth is well and alive all over the place.  8)
Nowadays, in the golden era of microcontrollers, embedded and Iot, it is spreading more than ever, especially because Forth has a very small footprint, and it's very easy to deploy to various architectures (a one man job, literally).
You can even practice it online if you like, no need to install or buy something (don't know if this is a good online IDE, just the first search result for 'Forth online'):
https://repl.it/repls/ShowyTerribleAdmin
Offline David Hess
  • DavidH
« Reply #9 on: September 05, 2018, 02:45:52 am »
The Open Firmware standard from Sun used FORTH to allow PCI expansion cards to operate on systems with different processors.  I guess that idea was too effective and too easy because it was replaced with Intel's EFI.
Offline borjam
  • EA2EKH
« Reply #10 on: September 05, 2018, 07:24:59 am »
Open Firmware was processor independent. You ported Forth and even the device driver firmware you would need to access from Open Firmware (boot support for disk controllers, etc) would be portable. I guess Intel liked the idea of a CPU independent device support just like Microsoft loved the notion of virtual machines and the Sun/Oracle "Network Computer" ;)
Offline David Hess
  • DavidH
« Reply #11 on: September 05, 2018, 12:34:18 pm »
Maybe Intel saw the potential for ARM to be a threat to their desktop market so killed processor independent firmware with EFI.  In any event, it is another great idea that is now dead.
« Reply #12 on: September 05, 2018, 01:51:05 pm »
Wow!... I'm glad it's interest is still current !!
When I said 'dead', I meant no longer prevalent as it was in the 80's, 90's.
The video link/post by  ebclr  amazed me !!!  The Video was honestly above my level, but I followed
enough to grasp the contemporary usefulness of the described Mecrisp Forth, on STM32 Microcontroller.
I loved the way 'Forth', not 'Fourth', (as the original system at conception could only handle 5-char filenames!)
was so immediately useable while defining 'words' without re-compiling etc. You could make it almost so
English like, in structuring commands/sentences, (seemingly) without a 'program' as such, but simply constantly
defining higher & higher level Words. (With parameters). Control of actual Inputs/Outputs was beautiful !!
I guess i was talking here, more to those that are un-familiar :-)
It was a strange beast :-)  The  first implementation that 'I' saw/had, was on a plug-in Cartridge on the
Commodore-64. This was before I found out about it's implementation in numerous chips/devices.
(35 - 40 years ago !!!  :-)  )
Online iMo
  • Country: pm
  • It's important to try new things..
« Reply #13 on: September 05, 2018, 07:22:09 pm »
Mecrisp Forth running on a J1a_enhanced CPU (UPduino iCE40UP5k FPGA)
https://github.com/igor-m/UPduino-Mecrisp-Ice-15kB
The following users thanked this post: GlennSprigg
Offline borjam
  • EA2EKH
« Reply #14 on: September 06, 2018, 11:26:38 am »
Yes, hence my sarcasm ;) Another great idea killed by the Wintel duopoly. And every time I have to deal with one of those hideous "BIOS" configuration tools, clearing the screen like naive Basic programmers and forcing you to shoot videos in order to catch rare errors I get violent.
FreeBSD has a Forth loader actually but without actual device drivers built in it's not so useful.
https://www.freebsd.org/cgi/man.cgi?loader(8)
Back in the early 90's you should have seen the face of a friend when I booted a Sun workstation, aborted the startup to get into OpenBoot (that's how they called OpenFirmware) and I typed several silly Forth words. He couldn't believe it!
Offline LapTop006
« Reply #15 on: September 07, 2018, 05:45:55 am »
EFI *is* processor independent. It mostly started off as the firmware layer for Intel Itanium machines, then Apple used it when they moved from (Open Firmware) PowerPC to x86, and now more recently UEFI has replaced the old BIOS for most x86-64 PCs, and it's even used by ARM64 servers.
It certainly does have it's weirdnesses, but so do all the firmware options.
Offline borjam
  • EA2EKH
« Reply #16 on: September 07, 2018, 07:19:04 am »
Open Firmware uses Forth, a high level language.
As long as you provide the right primitives in machine code, the rest of the code is processor indepent.
So, imagine that you have a PCI network card with some initialization code in firmware. If the firmware is Open Firmware, the same card with the same firmware in flash or ROM will work on a machine regardless of the processor. You don't need to choose SPARC firmware or PowerPC for example.
Is that possible in EFI? Having several compiled versions for different processors doesn't count. With Open Firmware you would support even future processors without touching the ROM or flash memory in the add-on card.
For someone not familiar with this notion, it would be similar to having firmware written in Python.
Offline guenthert
« Reply #17 on: September 12, 2018, 07:28:28 am »
OLPC-1 used Open Firmware too, which was a bit controversial due to the proprietary nature of the software and it being a one-man project (like virtually all FORTH projects).  Somehow FORTH seems to attract people interested in quick initial results, rather than long term cooperation.  Yeah, perhaps one could summarize FORTH as the quickest way to get to the 80% solution  ;)
Said that, FORTH does seem to be a good fit for the retro and steam-punk computers (usually single-person projects as well) and it sure is fun.  Over at forums.parallax.com Peter Jakacki quite actively maintains Tachyon, a fast FORTH implementation for the Propeller MCU.
Offline borjam
  • EA2EKH
« Reply #18 on: September 12, 2018, 10:18:16 am »
So people is using Linux on proprietary hardware with extremely proprietary processors and so on.
I remember when Intel was called "open" while SPARC (despite being an open standard) was considered "proprietary". Ah, doublethink!
Being one man or team work depends on your working style. I've used Forth in the real world 20 years ago and it was certainly a quick and efficient way to build an embedded application for an 8 bit microcontroller. Nowadays, when programming begins with mastering a complex mix of poorly docuemnted multi-gigabyte class libraries, it doesn't fit of course. But that's an entirely different story.
Compared to the two typical alternatives at the time, C and raw assembler, it was really awesome.
Offline TheNewLab
« Reply #19 on: December 13, 2018, 04:31:18 am »
US government still need FORTH programmers...go figure...
Offline EEVblog
« Reply #20 on: December 13, 2018, 05:12:31 am »
The data recorder that's in my logo photo runs Forth on a TMS320, compiler only available in German!
Online iMo
  • Country: pm
« Reply #21 on: December 13, 2018, 09:09:26 am »
None C at that time existed, imho..
Offline rrinker
« Reply #22 on: December 14, 2018, 06:34:54 pm »
 I just got finished with a project that was evaluating application being used by the client for compatibility with upgraded server infrastructure. At least one of them is STILL promarily customized by programming in COBOL.
 FORTH has intrigued me at various times but I never really set out to learn it - perhaps I should.
Offline rhb
« Reply #23 on: December 14, 2018, 10:55:39 pm »
The Kitt Peak radio telescope was programmed in forth.   And the airport baggage handling system at the Riyahd airport.  Forth, Inc. is still in business, so I'd say it's a safe bet forth is used a lot more than people think.
If you have to program a one off piece of real time hardware it's pretty hard to beat. It is the bare minimum you need to have a portable piece of software that accommodates incremental changes to the hardware gracefully.
This is in my view the best book for understanding the forth model:
https://www.amazon.com/Threaded-Interpretive-Languages-Design-Implementation/dp/007038360X
When I looked it up a week or so ago a copy was $10.
Offline tsman
« Reply #24 on: December 14, 2018, 11:09:36 pm »
Yes. You can have both types in UEFI. EFI Byte Code drivers which are processor independent but need a EBC interpreter and regular executables which are tied to that architecture or platform but may be executed directly by your OS. It is up to whoever implements it.
