For some reason I was thinking the SE had an internal high density floppy drive? Maybe that was a later edition of it? I know my SE/30 has an internal superdrive but that came out a bit later and was a high end machine at the time. That stuff was scary expensive back in the day.
Added bonus, this drive looks right with the SE styling despite being designed primarily for the II GS.
Quote from: djos on December 13, 2017, 08:55:25 pmAdded bonus, this drive looks right with the SE styling despite being designed primarily for the II GS.And they have even turned yellow/brown to the same extent! Seriously though, you can't bank on that, if one unit has seen a lot of sunlight and the other has been sitting in a shady spot. (Or is the yellowing mainly due to the light conditons in the picture in this case?)
Heat or UV will both do it. UV definitely plays a part though because I've had equipment that had a sticker on it that created a very clear shadow in the yellowing.Fortunately there are ways to reverse this to some extent. Mix some hydrogen peroxide with a bit of Oxy clean in a spray bottle, set the case out in the sun on a clear summer day and spray it down with the mixture. Keep misting it periodically to keep it wet and you'll be able to watch the yellowing vanish right before your eyes. Within about 15 minutes it should be substantially improved, that's what I did with my SE/30. Don't overdo it or the plastic will take on a chalky appearance that you can't fully recover. It will never be quite as light as it was originally but you can make it look WAY better than it was.
Very Nice! I assume it's a CP/M machine?
