Author Topic: HD out of a sony kv-27fs100?  (Read 1825 times)
Offline AutogolazzoJrTopic starter
« on: January 12, 2018, 01:47:37 am »
I own a sony trinitron tv, it's as old as me, but I just stumbled by this empty forum post.
http://www.avsforum.com/forum/64-direct-view-single-tube-crt-displays/350561-sony-kv27fs100-resolution.html
I thought svideo can't carry hd signal? Can my tv support a beyond 480i resolution? At least more vertical resolution?
Thanks.
Re: HD out of a sony kv-27fs100?
« Reply #1 on: January 12, 2018, 04:37:24 am »
Sony did make high definition computer monitors, so those are definitely capable of better than standard 640x480 SD video use.  they also did make professional broadcast monitors that are still used in studios on HD signals, using those same VGA CRT's, but a regular consumer Trinitron will probably not have the resolution for this higher resolution display.
The following users thanked this post: AutogolazzoJr
Offline bw2341
« Reply #2 on: January 13, 2018, 05:38:51 am »
S-Video can't support anything other than standard definition (480i here, 576i in PAL countries).
It looks like the post at avsforum is referring to the graphics card resolution in TV-out mode.
While 640x480 would seem like the natural resolution for TV-out, it's problematic in practice. All CRT TVs have overscan so you'll lose maybe 10-20 pixels all around the image. This would make the Windows Start menu difficult to use and cut off a lot of text on the screen. To compensate, the graphics card scales the image smaller than 640x480, leaving a black border all around.
Since the 1:1 pixel mapping is already lost, it doesn't matter what resolution you start with. The graphics card in that post can use 800x600 and 1024x768. The Windows desktop will be running at those resolutions, but the TV-out will still be 480i.
