Author Topic: Tandy 1000 ex/hx PLUS Expansion to 8-Bit ISA Riser card project  (Read 28193 times)
Online djos
Re: Tandy 1000 ex/hx PLUS Expansion to 8-Bit ISA Riser card project
« Reply #100 on: July 29, 2017, 09:52:18 am »
Put buffer/driver ICs to drive the extension?
That would likely do it, a bit beyond my current digital logic knowledge tho.
The impossible often has a kind of integrity which the merely improbable lacks.
Visit my Tindie store for Tandy 1000 Adapters for EX, HX, SX, SL, TX & TL etc
Offline bitseeker
« Reply #101 on: July 29, 2017, 09:53:46 am »
That's OK. Add it to the "things to explore" list. ^-^
You don't acquire TEA. It acquires you.
Online djos
« Reply #102 on: July 29, 2017, 09:59:03 am »
Indeed.  :-DMM
Offline bitseeker
« Reply #103 on: July 29, 2017, 06:47:49 pm »
Had you seen my video (posted just the other day) about using a floppy emulator to get 2.5mb floppy images on the Tandy 1000 EX? I used a $17 USD Gotek with 10 euro HxC firmware.  Also there is a video about using a 3.5" floppy internally on the EX. (Any 3.5" HD drive will do. The cable needs a small modification.)
That's a neat emulator. The HxC firmware says it supports over 8000 1.44MB images. With the Gotek emulator's 3-digit display, can you go past 999 (i.e., does it roll over)?
Online djos
« Reply #104 on: July 29, 2017, 09:14:10 pm »
Have you tested the IDE controller to see that it actually works?
So as per my more recent posts, the answer to this question is yes - I've got it working in my EX very nicely using c800h for the bios address and the XTP R566 Bios version for V20's and up (the stock XT bios also works).
Online djos
« Reply #105 on: July 30, 2017, 02:54:55 pm »
So I've had a fairly productive afternoon and completed both the Tandy 1000 Printer Adapter and PLUS-ISA/R Adapter v1.1:
Printer Adapter - Front:
Printer Adapter - Rear:
PLUS-ISA/R Adapter v1.1 - Front:
PLUS-ISA/R Adapter v1.1 - Rear:
I guess I just need to order some parts now! :D
« Last Edit: July 30, 2017, 03:40:11 pm by djos »
Online djos
« Reply #106 on: July 31, 2017, 12:17:24 pm »
I've had to make a minor change to the PLUS-ISA/R Adapter v1.1, I realised the solder pads where too close to the PLUS Socket (which is almost 2mm wider than it needs to be) by about 1.9mm and have tweaked it accordingly.
I've now placed an order for the Tandy Printer Adapter and PLUS-ISA/R Adapter v1.1 PCB's and the Tandy Printer Adapter components (34p edge connectors & DB25 Female Sockets).
« Last Edit: July 31, 2017, 12:33:06 pm by djos »
Offline DavinD
« Reply #107 on: August 01, 2017, 03:47:16 am »
That's awesome!  I saw Adrian's video as well and I ordered the firmware to flash my Gotek.  These are going to be some souped up Tandys.  I want to send you money.
Offline DavinD
« Reply #108 on: August 01, 2017, 03:56:15 am »
If the IDE controller had a right-angle connector, things would probably fit better.
Online djos
« Reply #109 on: August 01, 2017, 06:35:54 am »
Yeah I've been thinking I might just make a right angle IDE PCB to solve that problem and allow the c.f. Card to be accessed from the rear of the case.  :-/O
Offline DavinD
« Reply #110 on: August 01, 2017, 06:37:16 am »
I'm ok with the way it is, though.  I'm not too worried about the case closing.
Online djos
« Reply #111 on: August 01, 2017, 06:38:58 am »
My initial run of the ISA adapters will be about 20 units so I should be able to cover the current expressed demand fairly easily.  8)
Online djos
« Reply #112 on: August 01, 2017, 07:11:59 am »
Sorry but my OCD won't let me sell folks something I'm not happy with, the new PCB's will arrive in less than 2 weeks and I already have all the required connectors to build them.
So if you can please be patient with me I think it'll be worth the wait.  8)
Offline DavinD
« Reply #113 on: August 01, 2017, 07:36:43 am »
No worries.  Thanks for figuring this out!
Online djos
« Reply #114 on: August 01, 2017, 08:03:15 am »
My pleasure, it's been a fun learning experience.  :-DMM
Online djos
« Reply #115 on: August 02, 2017, 01:25:22 pm »
For those without Ram expansions in their EX / HX machines:
I had a chance to do some testing last night, I pulled my ram expansion out and installed my Lo-tech Compact Flash IDE board directly into the main-board .... and it worked great with no issues at all. The same went for a dual port ISA serial card, it worked fine too. My EX was definitely not as responsive but im not sure how much of that was caused by only having 256k of ram.
Anyhoo, I'll proceed with finishing the design of what I'm now calling the "PLUS-ISA Riser Card v1.0".  8)
Offline DavinD
« Reply #116 on: August 05, 2017, 07:11:36 am »
That's awesome.  I have the memory expansion, but this will be helpful for those that don't.
Online djos
« Reply #117 on: August 05, 2017, 07:19:12 pm »
Sooo, I think the Tandy 1000 PLUS-ISA Riser v1.0 board is done - space is a real issue so I've made the following compromises:
1/ There is less space between the bottom slot and the middle slot - the idea is that a very slim card like a Lo-tech ISA CompactFlash IDE would go on the bottom.
2/ The middle slot would be ideal for a slightly thicker card like an original ISA Serial Card
3/ the top slot would be ideal for a slim card like a lo-tech ram card that doesn't require rear access.
I'm happy to entertain others opinions on this design as I wont be needing one myself.
Offline bitseeker
« Reply #118 on: August 06, 2017, 06:43:07 am »
Congrats djos. Is this your first PCB-based "product"?
Online djos
« Reply #119 on: August 06, 2017, 08:04:37 am »
Thanks Mate.
Technically my Tandy 1000 EX /HX Floppy cable replacement is the first PCB based product I've actually sold (shipped about 3 so far):
Offline bitseeker
« Reply #120 on: August 06, 2017, 08:34:36 am »
Oh, didn't know you had already shipped them. So, these are the first and second, then. :)
Online djos
« Reply #121 on: August 06, 2017, 08:41:15 am »
Yep, and some folks asked me to make a Parallel port adapter too as most Tandy 1000's used an edge connector for that too. So that's about 4 products I think.  :o
PS, most of the Tandy fan boys I've met live over here.
Offline bitseeker
« Reply #122 on: August 06, 2017, 08:45:19 am »
Alas, the only Tandy I currently have is my CoCo1. But, I'm enjoying your projects.
Online djos
« Reply #123 on: August 06, 2017, 09:47:19 am »
Great little machine, I've thought about collecting a CoCo3 but every time I collect something I didnt own back in the day, it gets neglected or upgraded and sold off.
Offline bitseeker
« Reply #124 on: August 06, 2017, 05:00:10 pm »
Yeah, it's not quite the same.
