Author Topic: Higher flow with volcano nozzle and regular heater  (Read 11623 times)
Offline thmjprTopic starter
« on: August 08, 2022, 02:32:29 am »
Apparently if you need higher flow rates you can just straight up swap out the nozzle from a V6 to a volcano, no need for special orientation of the heater:
Adding some additional nuts or insulation helps but is not required.
There is also the CHT nozzle, released last year:
- Cost is about $20
- Same sort of performance as volcano
- Advantage is your Z height would be preserved
Or DIY CHT, some ways to attempt:
- Press fit a copper/brass rod into the nozzle, drill out a few holes (you'll need some small size drills and a good drill press)
- Press fit in some flat plates, maybe two at opposite angles, could even use an old penny (easiest method?)
- Solder in some flat plates or copper wires (if press fitting isn't secure or doesn't work)
- Drill and install copper wires, solder, as shown in the youtube channel above
The clones are using some press fit drilled method with copper:
No sign of solder that I see. Copper is theoretically best material to use, but in reality brass or aluminum would likely work as well.
I wouldn't buy a clone considering how expensive it is.
« Last Edit: August 08, 2022, 02:34:45 am by thmjpr »
Offline xchg.ca
    • Inside Out Electronics Youtube chanel
Re: Higher flow with volcano nozzle and regular heater
« Reply #1 on: March 16, 2023, 12:18:54 pm »
Nice idea !
I have pretty similar setup with my RigidBot ( Hemera + Volcano )
Using Volcano hot end was a pain with Hemera in term of cable management  |O
I have several V6 hot ends kicking around and multiple copper and even stainless steel Volcano nozzles!
I can definitely try this out, just need to get few brass nuts !!
Here is short vid of my setup
https://youtu.be/f5h9X5snYLE?t=259
