I'm making a custom keypad using Omron B3F-1050 momentary push button switches. I can order the caps from Omron, however I would like to label the caps, so will most likely 3D print them.
I have an older Prusa MK2, and the slicer software does allow addition of embossed text but I would prefer to embed the text into each the step file for each cap. Make a library of key caps.
I can manipulate step files in Altium so if I had just the embossed text as a step file I could add it to the existing step file for the cap.
I'm using an old version of Altium 13.3 and Win 7.
Is there a free text to embossed text 3D step file generation tool available?
