Did it arrive ok ?
Yes - it arrived. Delivery by Amazon for some reason.
All seems OK apart from one of the V-wheels on the pre-assembled Y axis when seems to have a crack/defect that means it won't move smoothly. Time to see what their customer service is like...
Thats a shame,
be interested to hear how you get on with a claim from them, that was our only reservation, though almost all other suppliers are just box shifters and would probably direct you to Creality anyway ?
Thankfully those V wheels ( and most other parts) are only a few £ and available from many uk sources if your claim is not delt with promtly.
Do check the printer base on a level surface, ours was uneven and also check the four bolts on the underside holding the whole Y assembly, a couple were quiet loose.
Also had to shim with card the Z motors plastic mounting block as the screw thread was not vertical, worked ok, but got a ebay aluminium block made for the job, fitted perfectly square.
