Author Topic: Creality K1 Max 3D Printer: Unboxing + Setup + First Print  (Read 18641 times)
Online EEVblogTopic starter
« on: November 10, 2023, 08:42:57 pm »
Creality K1 Max AI 3D Printer Unboxing + Setup + First Print
Too big for the usual Mailbag video.
Offline Infraviolet
Re: Creality K1 Max 3D Printer: Unboxing + Setup + First Print
« Reply #1 on: November 12, 2023, 06:26:35 pm »
Looking ata quick glance, I saw you setting up network settings, and cloud related stuff? Does that mean this printer is depenent on them, or can it run fully offline in a "slice stl to gcode on pc, copy gcode to USB or SD card, insert USB/SD in printer, select file from sick/card, print" mode?
Offline drago462
« Reply #2 on: April 05, 2024, 08:04:35 am »
I recently bought one of them I am pretty with the printing quality after tunning some parametters. I also have a X1 Carbon and the results are quite the same for the half of the price. The only con I found is you have to open the top when printing with PETG and it's quite noisy.
