Author Topic: First 3D Printer (if I may, uh.. Kind of urgent!)  (Read 10300 times)
Offline Zucca
  • EE meid in Itali
Re: First 3D Printer (if I may, uh.. Kind of urgent!)
« Reply #25 on: November 30, 2022, 04:44:34 am »
ABS is also actually post-processable. Good luck sanding PLA, it's awful.
As far as polymers go, the bulk of my FDM printing is done in polycarbonate in a heated chamber. Moderately priced, excellent mechanical properties, good dimensional accuracy. Absolutely needs a heated chamber though (same as ABS) or you'll not get good results.
As far as FDM materials go, for me:
* ABS for castings masters or similar parts that need to be post processed (and SLA isn't suitable)
* PC for general purpose usage
* PA6-CF (or PA12-CF/GF depending on specific requirements) for mechanically strong parts
* PVDF for chemically resistant parts
Respect, I can't imagine how much time you invested to figure all the above out.
Do you think I can do PC with an E3D V6 hotend upgraded to copper plated block and Pt1000/PT100?
« Last Edit: November 30, 2022, 05:39:30 am by Zucca »
Offline CatalinaWOW
« Reply #26 on: November 30, 2022, 10:16:42 am »
Odors and reactions to various filaments are something very personal.  I have not noticed any odor or reaction to any of the common filament materials, but more than one person I know reacts to one or more of them.
Medical concern has been raised about all of them, but I don't think there is enough data to make any definitive comments.  It would certainly be good practice to arrange for good ventilation, just as you would for soldering fumes, paint fumes and sanding dust.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #27 on: November 30, 2022, 12:07:15 pm »
Honestly, I've never noticed any odor from PLA whether melted or hard. I get right up to the print head sometimes to check how it's printing - never smelled any odor whatsoever.  :-//
Edit: Additional data - I use Atomic filament, if it matters.
« Last Edit: November 30, 2022, 12:21:46 pm by xrunner »
Offline KaneTW
« Reply #28 on: November 30, 2022, 07:23:24 pm »
I have no particular experience with E3D-style hotends and PC. It looks like it could work, though. I run my hotend at around 275C so you don't need super high temps.
My heatbreak is watercooled so the temperature gradient is a bit sharper than in consumer printers. I don't think it's a big problem for PC though as it has a moderately high Tg.
Offline Zucca
  • EE meid in Itali
« Reply #29 on: December 01, 2022, 01:08:26 am »
Thanks Kane.
Now I would like to see a pic of your setup.
How many printers you have?
Offline KaneTW
« Reply #30 on: December 01, 2022, 01:19:31 am »
Just two. A Form 3 and an Intamsys Pro 410 HT.
The Form 3 is excellent, but has the usual limitations of SLA and expensive materials.
The Intamsys is ok. It's good and works well, but there's some things (esp material handling and waste heat) that are a bit suboptimal. It was the best cost/performance for reliably printing high temp filaments at the time though, and all the mechanical parts are pretty solid. If it was a 10k device it'd be an excellent deal.
I had a Raise3D Pro2 Plus before the Intamsys for a couple months as a trial and it was an awful mess.
That being said, you can get good results with cheaper machines. It'll just require more time investment.
Offline Zucca
  • EE meid in Itali
« Reply #31 on: December 01, 2022, 01:52:48 pm »
Holy shhhh...  :scared: I knew you had big guns in your hand.... Congrats nice horses.
