Yeah, the voron is special. It's not a product but an open sourced design you have to build yourself, from almost scratch. Some components kits are available though. Can be fun.
Yep. I am actually thinking about it but a full kit is >1000€ + shipping. I am still using my Nophead's Mendel90 kit, with a lot of modifications. That one was like 800€ back in 2014
@janoc
a) Yes, but then my printer would be doing nothing for 5 hours during the night, and I would need two evenings.
Sure, but the issue is running the machine unattended. That would avoid it, without having to rely on hacks like the resume on power failure feature some printers have.
b) Someone is paying for it. Other manufacturing methods would be even more time consuming and expensive.
If one wanted a purely functional design, cutting those two things out of a sheet of plywood would likely do the same job. Or, heck, even a single slab of wood ... Both would be a lot faster to manufacture and almost certainly cheaper too, compared to the day long printing time (it is not just the filament cost but also the electricity, wear on the machine and the time needed to "babysit" the machine - even if for no other reason than to make sure it doesn't catch on fire ...)
Of course, having someone else pay you for doing that is a different matter. However, if we are talking only about printing times then my approach to making parts on my Mendel is to always print only things that really are difficult/inconvenient to manufacture otherwise - e.g. by cutting off and drilling a piece of wooden or metal stock (esp. for structural parts). A typical build uses e.g. cheap hardware store aluminum profiles joined by 3D printed components and perhaps a sheet of thin plywood to mount electronics on instead of 3D printing everything. As a result I rarely have to print pieces that take longer than 2-3 hours (no, the Mendel is really not fast, esp. not with its heavy direct drive Wade extruder sitting directly on the x carriage).
The software is what makes the printer a good experience to use or not.
Now people who are already committed to their ender will probably say this is a rubbish statement and their printer is fine. After many hours of tweaking.
I would look for a printer where there is either open source firmware for the controller board (e.g. a variant of Marlin supports the board) - or the board can be replaced/upgraded later for a more advanced one.
AFAIK (I don't own any Ender variant), Enders use Marlin, so if you don't like what the firmware does, it can be always reflashed with stock Marlin configured to your liking. I am sure there are even pre-made configs for these machines already.
Tweaking will be always required either way, IMO - each printer is slightly different, materials are different, people print different things, the machines need constant maintenance - so tinkering is to be expected.
That said - no amount of tinkering with firmware can fix a rubbish printer where every corner has been cut. So maybe buying that $99 wonder is not the best idea.
