Author Topic: Hmm, only a slight layer shift lol  (Read 8801 times)
Offline thm_w
  • Non-expert
Re: Hmm, only a slight layer shift lol
« Reply #25 on: August 24, 2021, 08:51:53 pm »
Its not reliable to measure temperature of aluminum like that.
You'll need to make the surface emissivity higher, normally put black tape or similar, but the high temp will melt it. Also the IR gun needs to be much closer. If you look at the instructions of the gun it will give you a ratio or angle.
https://www.fluke.com/en-us/learn/blog/temperature/how-to-get-great-results-with-an-infrared-thermometer
The following users thanked this post: HobGoblyn
Offline Bassman59
  • Yes, I do this for a living
« Reply #26 on: August 24, 2021, 09:51:30 pm »
I use kapton tape to secure a thermocouple bead to whatever and use my Fluke 179 meter to monitor the temperature.
The following users thanked this post: thm_w, HobGoblyn
Online HobGoblynTopic starter
« Reply #27 on: August 25, 2021, 07:23:37 am »
Thanks, I did test much closer and at different angles, didn’t make much difference (and keeping it in any one place, was jumping around all over the place). I took the pics further away so I could get the laser dot in the pic.
Just read the link, very useful info.
I think Bassman59’s idea is excellent and will give it a go later today.
« Last Edit: August 25, 2021, 07:30:12 am by HobGoblyn »
