Author Topic: I'm having trouble getting Marlin 2.0.9.3 wrork on Sanguinololu 1.3a control boa  (Read 2456 times)
Offline pcmadTopic starter
    • module web design
I'm having trouble getting Marlin 2.0.9.3 wrork on Sanguinololu 1.3a control board
The faults include locked up stepper motors  no temperature Output  End stops not acknowledging And a lot of things are not working the .
The only thing that does seem to work OK is the out of filament sensor
After looking at verbose mode on my arduino ide  I get these messages also uploading the firmware via a arduino as ISP
Sanguinololu  control board 1.3a Microcontroller atmel 1284p pu
J tag disabled  for end stop To work
Marlin 1.1.9.1 work perfectly
error log
/home/user/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /home/user/arduino-1.8.19/hardware -hardware /home/user/.arduino15/packages -tools /home/user/arduino-1.8.19/tools-builder -tools /home/user/arduino-1.8.19/hardware/tools/avr -tools /home/user/.arduino15/packages -built-in-libraries /home/user/arduino-1.8.19/libraries -libraries /home/user/Arduino/libraries -fqbn=Sanguino:avr:sanguino:cpu=atmega1284p -vid-pid=2341_0001 -ide-version=10819 -build-path /tmp/arduino_build_713268 -warnings=none -build-cache /tmp/arduino_cache_783826 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/home/user/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/user/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /home/user/Desktop/3dprinter/firmware/Marlin-2.0.x/Marlin/Marlin.ino
/home/user/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /home/user/arduino-1.8.19/hardware -hardware /home/user/.arduino15/packages -tools /home/user/arduino-1.8.19/tools-builder -tools /home/user/arduino-1.8.19/hardware/tools/avr -tools /home/user/.arduino15/packages -built-in-libraries /home/user/arduino-1.8.19/libraries -libraries /home/user/Arduino/libraries -fqbn=Sanguino:avr:sanguino:cpu=atmega1284p -vid-pid=2341_0001 -ide-version=10819 -build-path /tmp/arduino_build_713268 -warnings=none -build-cache /tmp/arduino_cache_783826 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/home/user/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/user/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /home/user/Desktop/3dprinter/firmware/Marlin-2.0.x/Marlin/Marlin.ino
Using board 'sanguino' from platform in folder: /home/user/.arduino15/packages/Sanguino/hardware/avr/1.0.3
Using core 'arduino' from platform in folder: /home/user/.arduino15/packages/arduino/hardware/avr/1.8.5
Detecting libraries used...
/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR -I/home/user/.arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/home/user/.arduino15/packages/Sanguino/hardware/avr/1.0.3/variants/sanguino /tmp/arduino_build_713268/sketch/Marlin.ino.cpp -o /dev/null
/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR -I/home/user/.arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/home/user/.arduino15/packages/Sanguino/hardware/avr/1.0.3/variants/sanguino /tmp/arduino_build_713268/sketch/src/MarlinCore.cpp -o /dev/null
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/MarlinCore.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/core/utility.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/feature/pause.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/feature/runout.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/calibrate/G28.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/config/M301.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/config/M302.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/control/M80_M81.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/eeprom/M500-M504.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/feature/pause/M600.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/feature/runout/M412.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/host/M115.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/motion/G2_G3.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/queue.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M104_M109.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M105.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M106_M107.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M140_M190.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M155.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M303.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/endstops.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/motion.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/planner.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/settings.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/temperature.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/tool_change.cpp
Generating function prototypes...
/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR -I/home/user/.arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/home/user/.arduino15/packages/Sanguino/hardware/avr/1.0.3/variants/sanguino /tmp/arduino_build_713268/sketch/Marlin.ino.cpp -o /tmp/arduino_build_713268/preproc/ctags_target_for_gcc_minus_e.cpp
/home/user/arduino-1.8.19/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_713268/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
Compiling libraries...
Compiling core...
Archiving built core (caching) in: /tmp/arduino_cache_783826/core/core_Sanguino_avr_sanguino_cpu_atmega1284p_69e06db4cea1daafc0a763812e40c218.a
Linking everything together...
Sketch uses 63574 bytes (48%) of program storage space. Maximum is 130048 bytes.
Global variables use 2636 bytes (16%) of dynamic memory, leaving 13748 bytes for local variables. Maximum is 16384 bytes.
/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega1284p -cstk500v1 -P/dev/ttyACM0 -b19200 -Uflash:w:/tmp/arduino_build_713268/Marlin.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/home/user/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega1284P
         Chip Erase delay              : 55000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10   128    0 no       4096    8      0  9000  9000 0xff 0xff
           flash         65    10   256    0 yes    131072  256    512  4500  4500 0xff 0xff
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/tmp/arduino_build_713268/Marlin.ino.hex"
avrdude: writing flash (63574 bytes):
Writing | ################################################## | 100% 60.17s
avrdude: 63574 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_713268/Marlin.ino.hex:
avrdude: load data flash data from input file /tmp/arduino_build_713268/Marlin.ino.hex:
avrdude: input file /tmp/arduino_build_713268/Marlin.ino.hex contains 63574 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 35.70s
avrdude: verifying ...
avrdude: 63574 bytes of flash verified
avrdude done.  Thank you.
Online Mechatrommer
  • Country: my
  • reassessing directives...
have you edited Configuration.h? can you post here?
Offline MarkF
I don't think you can build the Marlin 2.#.#.#  releases with the Arduino IDE because of memory issues.
You need to switch to VS Code to build it.
Some instructions on setting up VS Code:
https://marlinfw.org/docs/basics/install_platformio_vscode.html
and
The following users thanked this post: pcmad
    • module web design
Offline thm_w
  • Non-expert
The pins file you included was pins_SANGUINOLOLU_11.h
The config you selected was BOARD_SANGUINOLOLU_12
and the board you actually have is v1.3
https://marlinfw.org/docs/hardware/boards.html
The right pins file would be pins_sanguinololu_12.h, I assume thats what is being used and you just included the wrong one by accident.
1.2 and 1.3 hardware use the same pinouts according to here: https://reprap.org/wiki/Sanguinololu#Modifying_Older_Boards_.28from_Version_1.1_and_1.2_to_Version_1.3a.29
« Last Edit: April 02, 2022, 12:12:34 am by thm_w »
Offline MarkF
You select your board in the configuration.h file and the pins definition file is selected automatically.
Actually, the pins_SANGUINOLOLU_12.h includes the pins_SANGUINOLOLU_11.h file.
  #ifndef BOARD_NAME
    #define BOARD_NAME "Sanguinololu 1.2"
  #endif
  #define SANGUINOLOLU_V_1_2
  #include "pins_SANGUINOLOLU_11.h"
I assume the OP knows how to setup the Configuration.h and Configuration_adv.h files since Marlin 1.1.9.1 runs okay.  If not, I would suggest starting with the appropriate example config files for the printer.
F.Y.I.  Marlin 2.0 uses more memory than the similarly configured 1.9.1.1 version.  I heavily modified Marlin 1.1.9.1 for my CR-10 Mini.  So, I haven't updated to Marlin 2.0.  The ATmega1284P has very limited program memory and some options may need to be given up to run Marlin 2.0.
« Last Edit: April 01, 2022, 11:23:26 pm by MarkF »
Offline thm_w
  • Non-expert
You would think but look at the config file  ???
*   999 : Dummy Table that ALWAYS reads 100°C or the temperature defined below.
#define TEMP_SENSOR_0 999 // was 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_4 0
#define TEMP_SENSOR_5 0
#define TEMP_SENSOR_6 0
#define TEMP_SENSOR_7 0
#define TEMP_SENSOR_BED 998 // was 1
OP set them to the hardcoded values for some reason?
Was that just for testing?
Online Mechatrommer
  • Country: my
i checked the pins_SANGUINOLOLU_12.h, it will redirect to pins_SANGUINOLOLU_11.h anyway (with SANGUINOLOLU_V_1_2 defined) now the OP's only job is to make sure the pin assignment in pins_SANGUINOLOLU_11.h is correct with care attention to SANGUINOLOLU_V_1_2 keyword... Marlin is a big files, i will always make a comment with my tag name whenever i edit the value or add some codes, so later i can quickly search which part is mine skipping the rest of the default codes and values. its kind of my own version control, to make me easier for future update and only port files with my tag name to latest Marlin version. i suggest the same to OP and give us the tag name so we can quickly review. i'm currently using Marlin-2.0.7.2 here...fwiw...
i did the same on Marlin 1 that made me lazy to upgrade for the long time... but when checking the latest Marlin 2, i noticed some features that i was really needing/dreaming all the while such as resume on power outage, chamber temperature control etc... so i think its a worthy effort to ram the barrier... installed the platform.io + vs code barrier and redo the hardwork.. keeping notes on every step of it so i can review later... my next gen 3d printer, HW wise is 90+ % complete, FW wise is complete (at least runable on the new HW) the bad thing is i was tired doing it FW+HW so i currently put it on hold while i'm doing other stuffs.. my other 3 machines will surely benefit from this Marlin2 upgrade hardwork later... fwiw..
« Last Edit: April 02, 2022, 02:20:51 am by Mechatrommer »
    • module web design
yes for testing as temp was not reading due to marlin not working correctly
    • module web design
and
does vs allow upload via arduino as ISP as i could not get the  boot loader to work  if not it looks like and can take the bin file that vs made and use avrdude to upload via arduino as ISP
    • module web design
  #ifndef BOARD_NAME
  #endif
what would you say the ram / load useage difference would be in the 2 versions Marlin 2.0 vs Marlin 1.1.9.1
Offline MarkF
(It has been several months since I've looked at Marlin.......)
I have installed VS Code and setup Marlin 2.0.9.3 for my CR-10 Mini with the original Creality v1.1.3 board.  Using the example configuration files unmodified, I was able to build Marlin 2.0 with compiler optimization.  However, I was not able to get it to compile without optimization.  (i.e. The example config is right up at the limit of program space for the ATmega1284P.)
If you're looking to add a bunch of features to the example config, you will probably need to upgrade the motherboard.
I never tried to upload the binary to my printer.  I did make some effort to identify where I would need to make changes to incorporate my custom status display.  However, it was just more work than I wanted to do.
    • module web design
just to give you an update i got Marlin 2.0.9.3 on a Sanguinololu 1.3a board with a controller  atmel 1284p-pu compiled by VS studio  uploaded by an Arduino as an ISP using AVRDUDE  also if your using a 20mhz crystal make sure in VS you set the clock speed else you will have issues connecting and running the printer
