Products => 3D printing => Topic started by: thmjpr on October 22, 2022, 01:03:39 am
For those on the bleeding edge, of Marlin, experimental input shaping has been added:
https://github.com/MarlinFirmware/Marlin/commit/a460b01c876ff39901fe55a4b66b2c62737ef46c (https://github.com/MarlinFirmware/Marlin/commit/a460b01c876ff39901fe55a4b66b2c62737ef46c)
If you have an issue with ringing in your print, and want to print faster, might be worth looking at.
Its a manual calibration process, so you print a test piece, and measure the X and Y resonant frequencies on the print, then enter those in the config. AFAIK.
https://www.klipper3d.org/Resonance_Compensation.html (https://www.klipper3d.org/Resonance_Compensation.html)
Personally I just print a bit slower, but I also don't use a bed slinger.
