Author Topic: Input shaping now in Marlin  (Read 6291 times)
Offline thmjprTopic starter
« on: October 22, 2022, 01:03:39 am »
For those on the bleeding edge, of Marlin, experimental input shaping has been added:
https://github.com/MarlinFirmware/Marlin/commit/a460b01c876ff39901fe55a4b66b2c62737ef46c
If you have an issue with ringing in your print, and want to print faster, might be worth looking at.
Its a manual calibration process, so you print a test piece, and measure the X and Y resonant frequencies on the print, then enter those in the config. AFAIK.
https://www.klipper3d.org/Resonance_Compensation.html
Personally I just print a bit slower, but I also don't use a bed slinger.
The following users thanked this post: hfleming, xrunner
