Author Topic: KiCAD to OpenSCAD for PCB case generation  (Read 2921 times)
Offline Pineapple Dan
  • Country: ie
« on: January 21, 2022, 07:48:24 pm »
This is very rough and ready but it has saved me a great deal of time trying to manually place mount points for PCB cases
Basically I use the following python script to find where the mount holes are in the Kicad_pcb
MH = []
Valid_MH = ['MountingHole:MountingHole_4.3mm_M4','MountingHole:MountingHole_3.2mm_M3']
class MountHole():
    def __init__(self,raw_text):
        self.x = 0
        self.y = 0
        self.size = 3
        self.raw = raw_text
        self.parse()
    def parse(self):
        ls = self.raw.splitlines()
        for a in ls:
            if(a[:4] == "(at "):
                loc = a.split(" ")
                self.x = float(loc[1])
                self.y = float(loc[2][:-1])
    def OpenSCAD(self):
        return ("mount(" + str(self.x) + ',' + str(self.y) + "," + str(self.size) + ");")
        #print("m")
        #return "mount(" + str(self.x,'utf-8') + "," + str(self.y,'utf-8') + "," + str(self.size,'utf-8') + ")\n"
class Line():
    def __init__(self,raw):
        self.raw = raw
        #Start coords
        self.s = self.raw.find("(start")
        self.st = self.raw[self.s:]
        self.sta = self.st[:self.st.find(")")].split(" ")
        self.startx = float(self.sta[1])
        self.starty = float(self.sta[2])
        #End coords
        self.e = self.raw.find("(end")
        self.et = self.raw[self.e:]
        self.eta = self.et[:self.et.find(")")].split(" ")
        self.endx = float(self.eta[1])
        self.endy = float(self.eta[2])
        print(self.endx,self.endy)
class KCfile():
    def __init__(self,path):
        self.kfile = open(path,'r')
        self.mounts = []
        self.lins = []
        self.mods_text = self.getmods()
        self.getmounts()
    def par(self,string):
        return(string.count("(") - string.count(")"))
    def getmods(self):
        mods = []
        module_text = ""
        in_module = False
        open_bracket = 0
        for a in self.kfile.readlines():
            a = a.strip()
            if(a[:8] == "(gr_line"):
                self.lins.append(Line(a))
            if(a[:8] != "(module " and not in_module): continue
            in_module = True
            module_text = module_text + a + '\n'
            open_bracket += self.par(a)
       # print(a,open_bracket)
            if(open_bracket == 0):
                mods.append(module_text)
                module_text = ""
                in_module = False
        return mods
    def getmounts(self):
        mcount = 0
        for a in self.mods_text:
           mtype = a.split(" ")[1]
           if(mtype in Valid_MH):
               mcount += 1
               self.mounts.append(MountHole(a))
        print(mcount, "mount holes found")
    def OpenSCAD_mounts(self):
        minusx = 9999999999
        minusy = 9999999999
        hy = 0
        for a in self.mounts:
            #print(a.x)
            if(a.x < minusx): minusx = a.x
            if(a.y < minusy): minusy = a.y
        print("mirror([0,90,0])\nunion(){")
            if(a.y - minusy >hy): hy=a.y - minusy
            x = a.x-minusx
            y = a.y-minusy
            print("mount(" + str(x) + ',' + str(y  - hy) + "," + str(a.size) + ");")
            #print(a.OpenSCAD())
        print("}")
    def Gen_poly(self):
        pass
fl = KCfile('YOUR-FILENAME-HERE.kicad_pcb')
#print(fl.mods_text)
fl.OpenSCAD_mounts()
#print(fl.lins)
That script spits out a few lines like for example
mirror([0,90,0])
union(){
mount(0.0,0.0,3);
mount(65.34076,-9.57002,3);
mount(3.4696399999999983,-53.507639999999995,3);
mount(66.23075999999999,-52.560019999999994,3);
This I can paste into openscad and once I have my my mount() module defined somewhere ( very simple just one cylinder minus another)
module mount(x,y,size = 2.4, support = false) { // For 3mm screw
    translate([x,y,0])
    difference(){
    cylinder($mount_height,r=size);
    cylinder($mount_height + 0.01,r=(size/2));
Once u have the mount points in the right place its very easy to design a box around it, I do have a script to generate the boxes as well but I really need to clean that up before I even consider posting it anywhere. Still I hope this is useful to someone
Offline Doctorandus_P
Re: KiCAD to OpenSCAD for PCB case generation
« Reply #1 on: April 06, 2022, 04:58:45 am »
Are you aware of the KiCadStepUp workbench in FreeCAD?
Offline kripton2035
« Reply #2 on: April 06, 2022, 06:30:06 am »
+1. exporting a kicad pcb to freecad is really easy. once you tried it !
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #3 on: April 06, 2022, 08:51:59 am »
You don't even need StepUp for that. The standard STEP export from KiCAD is totally sufficient to get a model into FreeCAD that you can then use for checking collisions with your box etc.
However, not everyone is a FreeCAD user and having an automated way to export mounting points to OpenSCAD, which many engineers seem to like, is definitely appreciated.
Offline kripton2035
« Reply #4 on: April 06, 2022, 12:00:43 pm »
absolutely !
