YOU DO NOT
- Add flour, sugar, eggs, chips, etc. to a bowl
- Mix the dough
- Drop on a cooking sheet
- Bake for 10 minutes
- Let cool
- Eat
The analogy is not only a good explanation, but hilarious. I get the tree structure better now, but, to be a bit sarcastic. If I add a sketch (sketch1) to a face, and then 'pad' it or make it a 'pocket', the tree becomes <pocket> and underneath it <sketch1>. i.e. 'sketch1' is the last in the tree.
This is similar to adding "clean the plate" which now becomes the last item on the list under "eat", so (normally) I would have picked "clean the plate" thinking "clean the plate" wouldn't be included if I selected "eat the cookie". Hence, I'd lose "sketch1" because I selected the "pocket" above it.
Yes, I'm being a bit sarcastic, but I'm also pointing out that it's not as simple as picking the last in the list.
Now that I get the tree structure better, I should have less issues exporting.
