Author Topic: thermistor and heatsink compound  (Read 905 times)
Offline pcmad
    • module web design
« on: April 02, 2022, 01:40:13 pm »
I've just bought a new thermistor for my 3-D printer hot end the previous person who owned the machine put heat sink compound in the hole where the thermistor is located does this contaminate the sensor and give false readings or should that be fine please bear in mind that there is a 2mm bear wire gap from the sensor to the start on the insulation
please not if a was to use heat sink compound it will be the white stuff
Offline richnormand
Re: thermistor and heatsink compound
« Reply #1 on: April 02, 2022, 02:11:33 pm »
I have used silicone based white stuff before for both my 3D printer and thermistors for temperature stabilised diode lasers so I would assume you are OK.
The real issue would be to use some electrically conductive compound like the silver or copper based stuff that would shunt the thermistor and give a lower resistance reading.
Other thing to look for is that thermal compound tends to dry and cake so make sure the hole is clean and allows the full insertion of the new thermistor.
« Last Edit: April 02, 2022, 02:26:24 pm by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline TimFox
« Reply #2 on: April 02, 2022, 04:25:05 pm »
The "white stuff" is usually aluminum oxide, zinc oxide, or similar powder in the silicone vehicle that is a good electrical insulator and decent heat conductor.  It shouldn't contaminate the sensor.
A data sheet:  https://www.mgchemicals.com/downloads/tds/tds-860.pdf
Advertise on the EEVblog Forum
