Author Topic: Things to print  (Read 9092 times)
Offline mendip_discoveryTopic starter
Things to print
« on: January 14, 2023, 01:40:17 pm »
Now I have a printer I am trying to think of the things I would like to print.
My thoughts so far are,
Drill Guide for banana terminals.
Thermal shield for the calibrator at work and even the 34401A. Just to see how much it makes a difference on thermal EMFs
Thermal shield for K-type thermal couples the calibrator I use has a temp sensor in the connector and if I swap it between the channels I inadvertently warm it up a little. Plus to reduce any drafts.
What other things Electronics/Metrology related should I look at printing?
If I am trying to build a part is there a trick to making the various cutouts. For example, I want to print a project box with a 9pin com port on it, some banana connectors and to finish it off a BNC connector. Do you just keep a library of the cutout shapes and just apply them. Using Fusion 360 for now.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline Lindley
Re: Things to print
« Reply #1 on: January 16, 2023, 11:47:46 am »
Not something we have done yet, think Ytube is your helper there,
This one should give you the basic concept   -
Offline EPAIII
Re: Things to print
« Reply #2 on: February 21, 2023, 05:35:50 am »
Not directly Electronics/Metrology related, but I am presently working on a tool carousel for my work benches. I presently have three benches so I will probably make three of them. Each will have custom holes for the hand tools I frequently use at each bench. They should help cut down on the clutter. Or perhaps just make space for more. This is also a learning exercise for FreeCAD.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
