I have seen "the best of" reviews online, but they are mostly a review done by the URL/site, etc, so perhaps it's just bogus or AI generated reviews.
As example, chump gpt
If by **“small stepper motors”** you mean the compact motors used in **miniature 3D printers, compact CoreXY machines, and lightweight extruders/toolheads**—especially NEMA 8, 11, 14 and short-body NEMA 17—these are the brands I’d shortlist.
| Rank | Brand | Best small sizes | Why it stands out |
| **1** | **MOONS'** | NEMA 8, 11, 14, 17 | Excellent compact motors; strong torque density, low vibration, very good reputation in 3D printing |
| **2** | **LDO** | NEMA 14, 17 | Premium 3D-printer-focused motors; excellent consistency and low vibration |
| **3** | **STEPPERONLINE** | NEMA 11, 14, 17 | Very broad selection, good value, easy to source |
| **4** | **Applied Motion Products** | NEMA 8, 11, 14 | Excellent true miniature motors; specifically offers compact motors for space-constrained 3D printers Machine Design+1 |
| **5** | **Lin Engineering** | NEMA 6, 8, 11, 14, 17 | Particularly strong for genuinely miniature/high-precision motors |
| **6** | **Oriental Motor** | NEMA 8, 11, 14, 17 | Very established manufacturer with an unusually broad range of small frame sizes Oriental Motor |
| **7** | **Wantai** | NEMA 11, 14, 17 | Popular among DIY/3D-printer builders; good performance for the price |
| **8** | **Phidgets** | NEMA 11, 14, 17 | Convenient sourcing and well-documented motors; useful for prototypes and small machines |
| **9** | **Same Sky** | NEMA 11, 14, 17 | Higher-end compact motors, including encoder-equipped versions |
| **10** | **Pololu** | NEMA 8/11/14-class miniature motors | Excellent for small robotics/prototyping where physical size and easy sourcing matter |
If we narrow the target to **NEMA 17 with \~0.44 N·m (44 N·cm / \~62 oz-in) holding torque**, the field gets much more manageable.
One important point: **0.44 N·m is holding torque**, not the torque the motor will necessarily deliver while moving at your desired print speed.
### My shortlist
| Rank | Brand / model family | Torque | Typical body | My take |
| **1** | **LDO 42STH-series** | \~0.44–0.5 N·m | \~40–48 mm | ⭐ Best for 3D printers |
| **2** | **MOONS' NEMA 17** | \~0.44 N·m | \~40–48 mm | ⭐ Excellent quality |
| **3** | **StepperOnline 17HM19** | **0.44 N·m** | 48–72 mm depending model | Excellent value/selection |
| **4** | **Applied Motion HT17** | \~0.4–0.5 N·m | varies | Excellent industrial option |
| **5** | **Oriental Motor PKP series** | \~0.4–0.5 N·m | varies | Premium/very consistent |
| **6** | **Lin Engineering NEMA 17** | \~0.4–0.5 N·m | varies | Premium miniature-motion option |
| **7** | **Same Sky / CUI** | \~0.4–0.5 N·m | varies | Good engineering/OEM option |
| **8** | **Wantai NEMA 17** | \~0.44 N·m | \~40–48 mm | Good budget option |
| **9** | **Phidgets NEMA 17** | \~0.4–0.5 N·m | varies | Convenient prototyping choice |
| **10** | **Generic 17HS-series** | \~0.44 N·m | \~38–48 mm | Cheapest, but quality varies |
### The sweet spot I'd target
For a **small 3D printer**, I'd actually look for something around:
- **NEMA 17 / 42 × 42 mm**
- **0.40–0.50 N·m holding torque**
- **1.5–1.8 A/phase**
- **1.8° step angle**
- **\~40–48 mm body length**
- **\~5 mm shaft**
- **4-wire bipolar**
- **low inductance**, ideally roughly 2–4 mH
That gives you a good compromise between torque, motor size, weight, and high-speed performance.
### A particularly good reference point
LDO Super Motor 42STH48 2804AC-R 48MM
The **LDO 42STH48** is very much in the category I'd investigate for a 3D printer. It's a 48-mm-long NEMA 17 and is specifically marketed for 3D-printer applications.
For comparison, **StepperOnline has an exact 44 N·cm NEMA 17**, the 17HM19-1684D family. Its specifications are **0.44 N·m, 1.68 A/phase, 1.65 Ω, and 4.1 mH**. The particular encoder-equipped version is 72 mm long. Stepper Online
- NEMA 17 Bipolar Stepper 0.9° 1.68A 44Ncm$76.13Bearings Canada
### But I'd be careful about going too long
The exact 0.44-N·m StepperOnline motor I found is **72 mm long** in the encoder version. That's considerably larger/heavier than what I'd want on a small moving axis. Stepper Online
Their 0.44-N·m integrated-driver version is **69.5 mm long and 404.5 g**, so that's definitely not what I'd choose for a lightweight printer toolhead. Stepper Online
For a compact printer, **\~0.44 N·m in a 40–48 mm body** is the more interesting target.
### If this is for X/Y
I'd lean toward **LDO or MOONS'**, followed by a good StepperOnline motor.
If it's for **Z**, you can usually use a different motor because speed and moving mass aren't the same concern.
If it's for an **extruder**, I'd actually reconsider 0.44 N·m entirely—**a shorter/lighter NEMA 17 with \~0.25–0.35 N·m can be a better choice**, depending on the extruder gearing.
