Author Topic: Polygons overlap  (Read 1970 times)
Offline AgrumTopic starter
Polygons overlap
« on: December 13, 2018, 11:37:42 am »
Hello, I have a big polygon connected to "net A" and I want to create another polygon inside the first one connected to "net B".
Both polygons are on the same layer so when I do the second polygon it's overlapped to the first. How can I separate the 2 polygon between them without redo the first?
I hope that the question is clear,
thanks
Offline veryevil
Re: Polygons overlap
« Reply #1 on: December 13, 2018, 12:45:59 pm »
Go into the polygon manager and increase the priority of the polygon connected to B
The following users thanked this post: Agrum
« Reply #2 on: December 13, 2018, 01:47:19 pm »
Thanks, it works!!
Offline Deridex
  • IMHO
« Reply #3 on: December 15, 2018, 09:52:48 am »
You can also you Altiums automatic to generate the priorities. It works quite well and i tend to not do it manually.
