Author Topic: Altium: "3D Layout Mode" parallax settings  (Read 1751 times)
Offline TomorokoshiTopic starter
« on: December 17, 2018, 04:38:48 pm »
I have to make assembly documentation. I will take screen shots of the 3D views of the circuit assembly with part models. However, in 3D mode Altium applies parallax perspective to the rendering. Is there a way to change it or turn it off?
What I'm really looking for is the same zero-degree isometric no-perspective plan view as in 2D Layout Mode, but with the full board rendering using part models and colors.
Re: Altium: "3D Layout Mode" parallax settings
« Reply #1 on: December 17, 2018, 04:50:17 pm »
I found it:
Design -> Board Layers & Colors...
General -> Projection
Select between Perspective and Orthographic.
The following users thanked this post: ANTALIFE
