Author Topic: Unconected Net Label issue  (Read 1885 times)
Offline kaadamTopic starter
  • Country: hu
« on: July 02, 2015, 01:13:34 pm »
Hi Guys!
I try to compile a multi-channel design with 3 microcontroller block, each controller has 2 CAN channel, and i want to use 3 CAN bus.
Schematic: http://prntscr.com/7nxi3t
My problem is, Altium says the BUS net labels are not connected, but they are connected in the schematic. Do you know the solution (or the magic)?
Thanks!
Offline clive59
Re: Unconected Net Label issue
« Reply #1 on: July 04, 2015, 09:25:31 am »
Hi, looks like you have duplicate labels on each of the buses. Altium doesn't like that.
cheers, Clive
  • Country: hu
« Reply #2 on: July 05, 2015, 08:08:51 pm »
In other projects, it worked. It's very fustrating, i did not see the rule.. Anyway, i throw out the concept, not worth it.
Thanks!
Tapatalk-kal küldve az én A0001-el
Offline Zman
« Reply #3 on: July 12, 2015, 02:49:26 pm »
I believe this is set in project options (the tab with scope and visibility in multi-sheet design)
Information wants to be FREE!
