Author Topic: Circular array  (Read 1628 times)
Offline fcbTopic starter
    • Electron Plus
Circular array
« on: December 14, 2020, 03:28:27 pm »
AD20
Just doing a board, on it there will be a circular array of 72 parts, is there an easy(!) way of using a spreadsheet or similar to drive the locations X, Y, Theta for each of the parts?
Offline radar_macgyver
Re: Circular array
« Reply #1 on: December 14, 2020, 03:38:11 pm »
You can make a spreadsheet with 72 rows, and compute the X,Y and rotation of each part using a formula. Select all 72 of the X coordinates, then use the PCB list view, and paste in the 'X' column and it will paste all 72. Repeat for Y and rotation.
You can also make a polar local grid and do the same, this will simplify the formulas somewhat but is otherwise equivalent.
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Circular array
« Reply #2 on: December 14, 2020, 03:41:30 pm »
Just make a polar grid.  :palm:
“They Don’t Think It Be Like It Is, But It Do”
The following users thanked this post: ANTALIFE
    • Electron Plus
Re: Circular array
« Reply #3 on: December 14, 2020, 03:52:13 pm »
Brill thanks for both suggestions. Not used polar grids before.
    • Electron Plus
Re: Circular array
« Reply #4 on: December 15, 2020, 10:24:01 pm »
Didn't use polar grids in the end.  Used the "PCB List" feature and inserted data from a spreadsheet - worked perfectly thank you.
