What does your schematic look like? The PCB view isn't the problem here, so there isn't much to read from it.
Did you use Off-Sheet Connectors or Ports and Sheet Symbols to connect the sheets? Were they connected correctly?
A design that works (mostly) when flat, should probably be made flat... Hierarchical design is mainly only important when you have many repeated subcircuits.
