Author Topic: Altium designer component links  (Read 2950 times)
Offline geot51Topic starter
  • Country: gr
« on: June 07, 2017, 09:17:44 pm »
I drew a simple design with few capacitors just to learn how component links work in altium desginer. (Image 2, pic a)
I checked manualy one by one all capacitors and I saw that UIDs are matched with pcb document. (Image 1, pic a) In Project -> component links -> Perform Update, a message popup "component links are up to date" appeared.
I tried to change the designators of my schematic between two components. (Image 2 pic b) After I executed the changes on pcb document I checked again their UIDs manually. I saw again that the UIDs are still matched correctly. (Image 1 pic b)
However, when I hit again, Project -> Component Links... -> Perform Update, a message inform me that "Component links modified in... 2 Links modified" Which are those two links and how were they modified? The UIDs seemed to be matched even before I perform update.
Can someone explain that to me?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Altium designer component links
« Reply #1 on: June 07, 2017, 11:09:41 pm »
I regularly see links go "stale" for no obvious reason (i.e., editing parameters and moving components on SCH/PCB, without deleting/pasting/recreating any).
There may be UIDs associated with those kinds of objects (i.e., labels and parameters).  Who knows.
There's a lot of object and structure data that's hidden from view, yet vital to operation.  That's kind of true of any large software program, I guess, as fortunate and unfortunate as it is.
Seven Transistor Labs, LLC
