Think I've just made myself a real hum-dinger...
I have a component with plated slot type pads. They are connected to ground. Ground is assigned to an inner plane layer (plane, not polygon).
Can I control:
1. The angle of the plane connect reliefs? (an aside, it bothers me that they are a fixed 45 degrees and, seemingly, cannot be changed?! Whereas, for a polygon, the angle can be assigned.)
2. The shape of the 'expansion' (which appears to be copper generated uniformly around the hole/slot only, not clearance to the pad on that layer)?
The slot pads are currently defined as "simple" (same shape copper pad on all layers). If I use "top-inner-bottom" definitions, I could set the inner layers to zero (or less, anyway) so that the auto-generated 'expansion' serves as the pad. But what if I want to keep the pad shape the same on all layers?
Attached: pukey faded yellow color is the highlighted plane. You can see the pad overlaps the auto-generated 'expansion', violating the clearance gap (I haven't checked if this actually generates DRC, but it sure looks bad). The nearby pin, which has a round hole but an oval pad shape, also shows the same problem.
