Author Topic: Altium Designer 19.1.5: very dark 3D preview, black footprints  (Read 2523 times)
Offline sidlauskasTopic starter
Anyone facing the same issue? How this could be fixed? Tried to do a clean install, but it doesn't help. I'm on Windows 10 with all the recent updates.
Re: Altium Designer 19.1.5: very dark 3D preview, black footprints
« Reply #1 on: June 26, 2019, 02:51:52 pm »
I have the same. I thought it was a Parallels VM bug.
So it is common?
I'm also on Parallels 13 VM. Which version do you use?
Offline eliocor
    • rhodiatoce
« Reply #2 on: June 26, 2019, 08:48:57 pm »
NOT on pure Windows 10.
« Reply #3 on: June 27, 2019, 06:20:36 am »
So I guess it's due to Parallels VM :( Is there anyone else who also use the Altium on Parallels VM?
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: July 15, 2019, 05:02:42 pm »
select a component
select similar so all components are highlighted
right click a component now and select component actions
update from library.
that will resolve this.
you have a corrupt step file in a library somewhere.
Did you bring in designs from circuitmaker or circuitstudio by any chance ?  that is a known issue.
Offline ddavidebor
    • Smartbox AT
« Reply #5 on: July 15, 2019, 08:52:59 pm »
Similar issues on parallels.
Try messing with colors on the layer panels and thickness on the stack editor.
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
Offline ddavidebor
    • Smartbox AT
« Reply #6 on: September 04, 2019, 10:02:13 am »
Proposed solution: Use the software gfxcardstatus to check that your card is set to "dedicated", then reboot windows inside the VM
