Author Topic: Creating Altium Assembly Drawing Layer pairs  (Read 1306 times)
Offline Sahiru.DilanTopic starter
  • Country: lk
« on: August 26, 2020, 05:13:26 am »
Hey,
I tried to make layer pairs for Assembly Drawing as Robert describes in his tutorial https://youtu.be/L36KicrU45Q?t=1415.
I have Altium 20.1.14 and it seems like it does not work. Can anyone help me out here.
Thank you all  :) :)
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Creating Altium Assembly Drawing Layer pairs
« Reply #1 on: August 26, 2020, 02:05:35 pm »
Fairly Similar process
Right click on Component Layer Pairs >> Add Component Layer Pair
Give it a name
select the mechanical layer numbers for the top and bottom
and then set the layer type to "Assembly"
These are the pairs I use.
“They Don’t Think It Be Like It Is, But It Do”
