When you're plunking down a bunch of passives in a cluster and don't want to remember which component has which value, the hover-over information is quite useful. I use it to figure out which of the several bypass caps has the lower capacitance, to be placed closer to the IC. Otherwise, I have to cross-select. It's faster to use the heads-up.
