Author Topic: How to make air gap?  (Read 4606 times)
Offline rozehTopic starter
« on: November 10, 2015, 01:45:34 pm »
Guys
I'm trying to design Air Gap on my PCB but I don't know how to do it? any hint,clue,idea,...?
Thanks
Mark Twain — 'The two most important days in your life are the day you are born and the day you find out why.'
Online T3sl4co1l
    • Seven Transistor Labs
Re: How to make air gap?
« Reply #1 on: November 10, 2015, 02:25:13 pm »
Design rules?  Gapping what?  Clearance/creepage?
Seven Transistor Labs, LLC
« Reply #2 on: November 10, 2015, 03:42:29 pm »
Thanks T3sl4co1l for your answers to my questions
I'm talking about something like these holes on PCB:
Is it clear?
Online T3sl4co1l
« Reply #3 on: November 10, 2015, 03:45:51 pm »
Ah, routed slots are made with a Region object.  Set its property to "board cutout".  Make sure the cutout appears on the Board Outline layer (usually Keep-Out) as well.
Check with your board house to see what minimum width and inside corner radius is reasonable.  Usually the milling bit is 1mm, so a 1.1mm or larger slot is no problem.  Smaller slots can be made (even between SOIC pins for minimum leakage), but they will probably add cost.
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: November 10, 2015, 04:58:00 pm »
the easiest way is to draw a line on a mechanical layer with the width of the slot. for example a 2 mm wide line.
once you have drawn the line or lines : select them.
Tools - convert - Selected objects to Board cutout
Offline Richard Head
« Reply #5 on: November 23, 2015, 12:31:09 pm »
The board house I use suggests using overlapping pads (multilayer) with the end pads dictaing the start and finish of the slot. The slots end up plated internally unless otherwise stated. If you don't want it plated then it will be routed after plating the board.
