Author Topic: Changing defaults for polygon?  (Read 3272 times)
Offline KorkenTopic starter
« on: November 21, 2014, 09:18:58 am »
Hi all,
I just upgraded to Altium 15 and a strange thing started happening.
When I draw a polygon and accept, the polygon becomes automatically shelved, and this is something I do not want.
I googled like crazy to find where to set this, but to no avail. Under the "normal" defaults at Preferences ->  PCB Editor -> Defaults -> Polygon there is no setting to turn of automatic shelving.
Does anyone know how to fix this?
I have logged a case with Altium, but the response time is not super.
Thanks!
Offline marshallh
    • retroactive
Re: Changing defaults for polygon?
« Reply #1 on: November 21, 2014, 08:12:23 pm »
in version 14.3 they changed the polygon behavior. There is no "shelving" anymore. Now they are "poured" or "unpoured".
What happened is that you drew a polygon and it became unpoured. You must set it to poured either in its properties or in the tools >polygon menu.
Also it's possible you created a polygon on another layer that was hidden from the current view, so you can't see it.
Verilog tips
BGA soldering intro
Offline Rufus
« Reply #2 on: November 21, 2014, 08:27:56 pm »
I haven't installed it yet but I thought I read in version 15 they bought back the concept of shelved and unshelved polygons.
« Reply #3 on: November 22, 2014, 11:35:55 am »
I got an answer from Altium, apparently of you import your settings from 14.3 there is a bug that makes all polygones go Shelved.
The fix is to (while the software is off) to find the ADVPCB.DFT file in 'C:\Users\xxxx\AppData\Roaming\Altium\Altium Designer {xxxx-xxxx-xxxx-xxxx-xxxx}', and in this file
locate the the statement SHELVED=TRUE and change that to SHELVED=FLASE
Hopes this helps someone.
Original discussion: http://forum.live.altium.com/#posts/207601
