Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
How to select multiple pads easily
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How to select multiple pads easily (Read 1889 times)
ali_asadzadeh
Super Contributor
Country:
on:
December 09, 2018, 03:08:35 pm »
I want to select some pads like dragging a rectangle to select them and use Interactively route multiple connections, But It seems the selection box does not allow me, and I should select all the pins one by one, do we have something in aid?
Logged
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: How to select multiple pads easily
Reply #1 on:
December 09, 2018, 05:34:09 pm »
If you want to avoid the popup box thingy, lock the component (right-click on it, or set its property any other way).
Unfortunately the built-in select won't do non-free pads. You could query it, maybe even write a script to make a mouse-driven InRegion query command that's more powerful than select, but yeah, more effort to figure it out.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Deridex
Regular Contributor
Country:
IMHO
Reply #2 on:
December 10, 2018, 06:37:06 am »
Try to keep the Ctrl-Key pressed while dragging the rectangle.
Logged
ali_asadzadeh
Super Contributor
Country:
Reply #3 on:
December 10, 2018, 11:54:21 am »
Thanks
Logged
mengfei
Regular Contributor
Country:
Reply #4 on:
December 18, 2018, 06:21:42 am »
Edit > Select > Toggle Selection
now you can click on each pad w/o shift/crtl key
Logged
ali_asadzadeh
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
