Author Topic: multiple chip pins with same output compiler error  (Read 1869 times)
Offline MorgorothTopic starter
  • Country: cl
« on: June 04, 2018, 01:16:30 pm »
Hi all, well, I have a problem in Altium, I'm designing a raspberry pi hat, and I'm using an automotive Quad high-side switch as power outputs. The high-side switch use 4 pins for a single power output and in the schematic, I just join them together (as in picture attached), but Altium complains when I compile the project. I can live with that error, but for sake of a pristine job, I want to solve it properly.
thanks in advance,
JP
« Last Edit: June 04, 2018, 01:21:31 pm by Morgoroth »
If works, doesn't means it is right.
Offline voltsandjolts
Re: multiple chip pins with same output compiler error
« Reply #1 on: June 04, 2018, 03:59:24 pm »
Altium compains when there are multiple output pins on one net. Change pins to passive or change the rules.
The following users thanked this post: Morgoroth
Offline Batang
  • Country: my
« Reply #2 on: June 05, 2018, 04:55:43 am »
Pin output is assumed to be push-pull, so hence the error.
Change pin to passive as has been suggested.
Cheers
