Author Topic: Parameters in properties in schematic library AD18  (Read 1813 times)
Offline Kanc1erzTopic starter
  • Being a noob the whole life :)
« on: April 06, 2018, 10:54:13 am »
Hello!
I have my own library of components in AD and when something is missing what I need I usually add them. Now I created the first component (Bluemod+S50, in AD18), however I cannot find a menu, where I can change parameters like: designator, comment, description, etc...
In older versions of AD I did it by using shortcuts - "T", "I", which enabled me to change everything I needed.
What's interesting, my workmate has a tab in properties called parameters, but I cannot find a place, where I can enable it. Can anyone help me?
Below screenshots:
AD18:
AD9-17:
« Last Edit: April 06, 2018, 10:59:36 am by Kanc1erz »
Re: Parameters in properties in schematic library AD18
« Reply #1 on: April 06, 2018, 11:00:29 am »
Yes, I know. I expanded it on screenshot. What is the next step?
« Reply #2 on: April 06, 2018, 11:05:40 am »
Click the model name in SCH Library tab, then its properties can be modified in Property tab.
Thanks a lot!
I wonder how many more such "surprises" I will come across....  |O
Thank you one more time  :-+
