Author Topic: How to run simple keyboard macros ?  (Read 2472 times)
Offline snoopyTopic starter
    • Analog Precision
« on: May 10, 2018, 01:09:36 pm »
I could have sworn I used to be able to do this in Protel but is it possible to assign a sequence of a few keyboard or menu commands to a single stroke sequence in Altium ?
cheers
Offline voltsandjolts
Re: How to run simple keyboard macros ?
« Reply #1 on: May 10, 2018, 02:51:49 pm »
You can edit the shortcut keys (https://techdocs.altium.com/display/ADRR/Shortcut+Keys) but I'm not aware of any way to combine several into one keystroke within Altium.
Maybe try https://autohotkey.com/ - its free and very good.
Offline ajb
« Reply #2 on: May 10, 2018, 10:02:08 pm »
You can assign user scripts to shortcut keys, if that works for you.
    • Analog Precision
« Reply #3 on: May 11, 2018, 06:53:11 am »
Would have been nice for Altium to generate a command line equivalent of each action like it can with the Filtering function. And then you can later copy and paste and create a macro from it.
Not everyone has the time to fiddle around with Pascal scripts !
cheers
Offline free_electron
    • SiliconValleyGarage
« Reply #4 on: May 23, 2018, 03:36:18 pm »
cheers
simply store the filter in your preferences.
