Author Topic: Altium PCB editor configuration issue  (Read 1795 times)
Offline ramonestTopic starter
« on: May 24, 2018, 07:10:07 am »
Hello,
I have a small but rather anoying issue with my configuration on Altium PCB editor. I used to be able to "ctrl + click" on a pad/trace and it select a net, highliting it but with the other elements still visible. I don't know if I changed something with the configuration but now when I do the same it changes the color of all other parts to black. It's not usefull anymore.
It'd be really helpful if to know what configuration I messed up.
I attach images of what I comented.
Thanks in advance.
Offline ajb
Re: Altium PCB editor configuration issue
« Reply #1 on: May 24, 2018, 03:40:52 pm »
Looks like you need to change your mask level.  I don't remember where the setting is, but you can increase or decrease by using the [ and ] keys to darken and lighten the display respectively.
The following users thanked this post: ramonest
« Reply #2 on: May 24, 2018, 04:38:27 pm »
Tanks so much ajb!
I didn't know it was called "mask levels".
By the way as you said Altium tells on their web page that "[" and "]" keys are used to decrease and increase respectively the mask level. But in my case, I guess it's because a different keyboard layout, I need to use " ' " and "ยก". I have a Spanish keyboard layout if some one finds it useful at any point.
Anyway, thank you again.
