In Altium 17 schematics, I have USB2 and USB3 connections. I am placing a blanket and a differential pair directive. In the directive, I add some other parameters such as class name and differential routing rules. When I update PCB document, Altium generates a lot of rules in Design->Rules for each net. I am doing exactly same thing for other differential signals such as USB2. In PCB editor the USB2 rules are generated for USB2 netclass, which is correct.
I deleted all the rules in PCB and updated again PCB from schematics, but it is still generating rules for nets, not for netclass USB3.
Here is the blanket and differential pair parameter for USB2 and USB3:
Differential pair parameter for USB2:
Differential pair parameter for USB3:
USB3 signals are added correctly in Netclass in PCB editor:
But there are a lot of rules for USB3, because it generated rules for "net" not for "netclass"
How can I generate rules only for netclasses not for nets?
How can I rename differential pair rules in schematics, instead of names such as "Schematic Differential Route_29"?
