X-Y on pcb is a no-no!
Mirrored parts is very common trap from datasheets (some gives you pads in top view and some in bottom (mirrored)), if you add and X-Y mirroring in PCB you will have great time debugging your boards.
Only space to rotate and L for layer change.
*For schematic is great though with 0 problems.
