arfff i thinked about it, but it seems a bit trash ... another idea ?
How is it trash? You can stack the pins and it means only one pin is needed on the schematic.Anyway, I've used both methods above and it works, so not sure what you are missing.
it's trash cause the replace/variant an other like function may will have problem to reassign pin in case of swapping component.first method don't works for me, i use altium nexus. and i don't know what i could forget.
i dont have... it's my first edge connector with altium. have you one in library ?to make my edge connector i mod my symbol (12 pin connector) to a jumper type symbol (in place of standard), i made my 2x12 pad edge connector footprint (both side pad are named as pin : 1...12)and i added jumper property value as named.... so 1 to 12 jumper value.i get 12 error : duplicate pad designator on Pads.....
