Author Topic: changing mil to mm shortcut  (Read 3526 times)
Offline ali_asadzadehTopic starter
« on: April 24, 2020, 07:49:54 am »
when I'm in PCB editor I can press "Q" to change the units to mm and mil, But when I open the rules window, this shortcut would not work! I want to know is there any shortcut so that it can be used to change units in the rules window?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: changing mil to mm shortcut
« Reply #1 on: April 24, 2020, 12:14:58 pm »
Pretty sure Design Rules take what ever units your PCB is using, so nope?
Offline ajb
« Reply #2 on: April 24, 2020, 04:30:50 pm »
Use Ctrl+Q inside dialog windows
The following users thanked this post: thm_w, sean0118, ANTALIFE, I wanted a rude username
« Reply #3 on: April 24, 2020, 05:31:02 pm »
Thanks ^-^
Offline reagle
    • KuzyaTech
« Reply #4 on: April 26, 2020, 05:32:26 pm »
Gets me every time. Still wondering why not keep it consistent?!
