Author Topic: 99SE how to close the paste mask over a pad (fiducial)?  (Read 3986 times)
Offline DTJTopic starter
« on: June 29, 2014, 12:39:21 pm »
I can't for the life of me find how to close the *paste* mask over a pad so the finished pad is not tinned during manufacture.
Checking the pad properties there is an (advanced) option for paste mask "override". I've tried various values including negative values and it seems to have no effect on the paste mask around the pad.
Any help please?
Thanks.
Re: 99SE how to close the paste mask over a pad (fiducial)?
« Reply #1 on: June 30, 2014, 01:18:58 pm »
I'm not 100% certain but I think putting a -ve value in the paste override value works.
The pcb view does not change but a preview print of the paste mask shows the "hole" disappear.
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: June 30, 2014, 01:24:04 pm »
Double click pad. Set paste opening to negative value of pad diameter.
« Reply #3 on: July 01, 2014, 10:41:34 am »
Thanks F_E that seems to work well.
