Author Topic: Adding "designator" to top layer drawn with "fill" command in altium  (Read 1217 times)
Offline electronxTopic starter
I'm pretty new to altium. I'm trying to draw a USB micro footprint, I usually use footprintwizard, but I wanted to draw from scratch.
I used the fill command and then added the paste mask extension and solder mask extension. However, I saw that I cannot assign a designator to this pad. Is there a way to add a desginator to this or is this a feature added to unconnected pads for stability? otherwise I will have to continue with add pad.
« Last Edit: June 29, 2022, 02:30:23 pm by electronx »
Offline ajb
Re: Adding "designator" to top layer drawn with "fill" command in altium
« Reply #1 on: June 29, 2022, 06:19:49 pm »
Why use a fill for this instead of a pad?
Sometimes you might need to use a copper region to create a pad that isn't one of the available pad shapes, in that case you would add a small pad somewhere within the region and assign the designator to that pad to create electrical connectivity to the region.  But that shouldn't be necessary for a simple rectangle pad.
For mechanical pads, I would typically assign them all the designator "M" so that one pin in the schematic symbol can create connections to however many pads the footprint needs, this makes it easy to use the same sch symbol for different parts with different numbers of mechanical pads.
The following users thanked this post: thm_w, electronx
Offline thm_w
  • Non-expert
« Reply #2 on: June 29, 2022, 10:02:33 pm »
You can watch some tutorials, or open existing footprints to get an idea how they were made
« Reply #3 on: June 30, 2022, 11:35:42 am »
"in that case you would add a small pad somewhere within the region and assign the designator to that pad to create electrical connectivity to the region."
thats the answer what i need.
some resources
https://www.altium.com/documentation/altium-designer/working-with-custom-pad-shapes
https://electronics.stackexchange.com/questions/309364/altium-footprint-using-lines-arcs-and-shapes
https://electronics.stackexchange.com/questions/195412/altium-issue-pcb-switch-pad-nets-for-rubber-button
« Last Edit: June 30, 2022, 11:56:33 am by electronx »
