Author Topic: Default sheet size  (Read 1772 times)
Offline mgulinTopic starter
  • Country: hr
Default sheet size
« on: April 27, 2018, 09:53:49 am »
Hi everyone,
It seems that Altium defines the A4 sheet size as 292.1mm x 193.04mm, while standard A4 size is 297mm x 210mm.  :-//  :palm:
I know that I can set the custom size for a single sheet, but is there a way to set this "custom size" as a default for all new sheets?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Default sheet size
« Reply #1 on: April 27, 2018, 10:19:15 am »
Yes, create a template and set your defaults there.  Including title block and parameters, too. :)  Then set that template as default.
Seven Transistor Labs, LLC
The following users thanked this post: mgulin
  • Country: hr
« Reply #2 on: April 27, 2018, 02:19:58 pm »
That did the job! Thank you!  :)
