Author Topic: Need to disable pullback in Altium Designer  (Read 953 times)
Offline c64Topic starter
« on: April 29, 2022, 06:37:59 am »
4 layer boards. I place embedded board array in Altium. Embedded board has power planes with pullback set to 0.
However, when I generate gerbers, it still places (although very thin) trace around the edge of embedded board  on both power planes.
Any way to disable this?
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Need to disable pullback in Altium Designer
« Reply #1 on: April 29, 2022, 12:39:13 pm »
I'd recommend you stop using planes, most people have switched to positive polygons instead of planes. Then just scope a board outline rule to your polys and set it to 0.
“They Don’t Think It Be Like It Is, But It Do”
