Author Topic: Schematic Sheet interconnect  (Read 1921 times)
Offline HarvsTopic starter
« on: January 20, 2017, 11:15:15 pm »
I'm trying to understand the best way of doing a multi-sheet design as it gets quite large.
From my understanding, there's two ways in Altium; Flat or Hierarchical.
Reading online it seems everyone is saying that Hierarchical is the only way to go, and indeed from what I've done I don't believe you can do Repeat symbols without it (at least it didn't work for me.)
But then I look at the Fedevel OpenRex board, and it's clearly a flat design.
While I can see the virtues of a Hierarchical approach, the actual sheet symbol interconnect seems to get very complicated when you have say 10+ sheets with each sheet connecting to more than one other sheet.  Or am I missing something...
Online T3sl4co1l
    • Seven Transistor Labs
Re: Schematic Sheet interconnect
« Reply #1 on: January 21, 2017, 01:35:37 am »
Flat is perfectly fine when you're not repeating sheets, and the interconnection is more general than tree-like.
In a flat design, you can use Port symbols, or use Off-Sheet Connectors.  Wires named with the same Net Label will also be connected, but you should try to avoid that because it leads down the slippery slope of graphical netlisting*.
*I don't know if anyone calls it this, but consider: a netlist is a plain-text representation, naming every pin of every component, and which nets those pins go to.  Utterly useless for seeing how a design is connected up.  Now consider a schematic design, where components are placed wherever, and each pin has a net name on it, no wires needed...
Seven Transistor Labs, LLC
« Reply #2 on: January 21, 2017, 03:39:12 am »
Flat has certainly worked for me with a large design recently, however is there a way to repeat sheets with a flat design?  Or does that mean you have to go Hierarchical?
Offline Someone
    • send complaints here
« Reply #3 on: January 21, 2017, 07:36:27 am »
You'd think that would never happen and then...
https://www.eevblog.com/forum/projects/overcomplicated-audiophool-dac-design-review/?all
