Author Topic: Remove Silkscreen from pads  (Read 1571 times)
Offline antoniobetaTopic starter
« on: April 04, 2020, 04:26:09 pm »
I have notice this post was posted twice for some extrange error, when I try to delete it I get this error:
You cannot delete your own topics in this board. Check to make sure this topic wasn't just moved to another board.
So please use the post at:
https://www.eevblog.com/forum/altium/remove-silkscreen-from-pads-236152/
Hello Everyone!
I am finishing a design on Altium and I have just encountered a problem.
The graphic I want to print on the silkscreen PCB covers some of the pads on the top layer, I know some manufacturers will fix that problem directly on the GERBERS before manufacturing, but I was wondering how could I made that myself on Altium designer 20 so I don’t depend on the manufacturer implementation.
Pictures 1, 2, 3 are screenshots of my design so you can see what I mean.
I have tried the trim silkscreen tool inside Altium but the result I got is picture 6 (the before is picture 4).
Any idea?
« Last Edit: April 04, 2020, 10:24:55 pm by antoniobeta »
Offline envisionelec
Re: Remove Silkscreen from pads
« Reply #1 on: May 08, 2020, 01:05:53 pm »
Aside from manually generating new artwork, you can make a note on your fabrication drawing to "eliminate silkscreen over any exposed or plated copper surfaces."
