Author Topic: Multilayer vias missing copper in middle layers  (Read 2358 times)
Offline plazmaTopic starter
    • Homepage
« on: March 18, 2020, 10:00:32 pm »
I exported the gerbers and compared to the layout. Top to bottom vias seem to be missing annular rings in middle layers.
In the picture left picture is from ViewMate gerber viewer. Right is AD20 with via properties visible. There should be the same 0.7mm dia annular rings in every layer.
How do I fix this or is there a setting for this?
Offline thm_w
  • Non-expert
Re: Multilayer vias missing copper in middle layers
« Reply #1 on: March 18, 2020, 10:15:26 pm »
Try it with "simple" stack for the via setting, see if it makes a difference.
Try a different gerber viewer, how does it show up in camtastic for example?
Online langwadt
« Reply #2 on: March 18, 2020, 10:26:23 pm »
may or may not be related but removing annular rings where they are not needed is a thing
https://en.wikipedia.org/wiki/Non_functional_pad
    • Homepage
« Reply #3 on: March 18, 2020, 10:31:01 pm »
Tried two other gerber viewers and they show the same.
If this is a matter of non-functional pad removal then there should be a setting for it.
Offline thm_w
  • Non-expert
« Reply #4 on: March 18, 2020, 11:01:55 pm »
If going back to "simple" stack doesn't do it, could try restoring them: https://www.altium.com/documentation/altium-designer/removing-unused-pads-and-adding-teardrops-ad
If you turn off multi-layer do they normally show up on a layer? I don't think I've ever had that off so I can't recall. It should show up in the 3D view in altium though.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: March 19, 2020, 07:29:04 am »
NFP is a setting in Gerber generation. It's recommended to be used, and is on by default.
Seven Transistor Labs, LLC
    • Homepage
« Reply #6 on: March 19, 2020, 10:55:55 am »
Thanks for the replies.
There is a setting "Include unconnected mid-layer pads" in Gerber Setup.
