Author Topic: Altium DRC: Hole-to-hole between microvias on different layers  (Read 1912 times)
Offline TheUnnamedNewbieTopic starter
  • mmwave RFIC/antenna designer
Altium keeps flaggin my RF footprints. Why? It has a M2->M3 via that is semi-overlapping with an M3->M4 via. The manufacturer has confirmed that this is fine for them, there is no rule with regards to vias on different layers.
How do I make Altium drop this without removing my hole-to-hole clearance rule, and replacing it with a separate rule for each substrate layer?
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Altium DRC: Hole-to-hole between microvias on different layers
« Reply #1 on: July 01, 2021, 02:35:04 pm »
Do you have this box checked?
“They Don’t Think It Be Like It Is, But It Do”
